#654884 - 26/03/03 06:58 PM 30,000 Mile Tune Up
loopit Offline
Loc: Annapolis, MD
My X has 30,000 miles and I have a few questions about the tune-up.
I looked at the PCV filter and it looked and sounded fine when rattling it. Do I really need to replace it?
Is it difficult to do the "Front-wheel bearing grease & free-running hub grease" and "Limited-slip differential gear oil"? If not, how do I do it? If so, how much would this cost at the dealer?
I need to replace my brakes cause they started to squek. I checked out XterraParts.com and they are $60. Are these the only ones that I should use or are there cheaper ones that work just as good available at like Advanced Auto Parts? How much do these usually cost?
Jeff
#654885 - 26/03/03 09:39 PM Re: 30,000 Mile Tune Up
defibvt Offline
7
Loc: AZ
Sounds like the PCV filter is good but heck change it anyway. It is pretty inexpensive to replace.
I haven't done my hubs yet but they are planned for this spring.
As for T-case fluid I would recommend getting a small hand pump to fill it. OffroadX post instructions at one time on here so do a search and you should be able to find them.
I did my brakes last year. They will run you about 50 bucks at Checker Auto parts for Raybestos pads. They are simple to do. In fact, purchase a Chilton/Hayes book for the year of your truck and you should be able to find instructions to help you do all the work you want to do.
