#658794 - 18/04/08 01:49 AM OBD II Codes
Anyone got a good website they use to research OBD-II codes?
#658795 - 18/04/08 05:56 AM Re: OBD II Codes
OBD Web-site
P1105
MAP/BARO Pressure Switch Solenoid Valve
P1126
Thermostat Function
P1130
Swirl Control Valve Control Solenoid Valve
P1148
Closed Loop Control (Bank 1)
P1165
Swirl Control Valve Control Vacuum Switch
P1168
Closed Loop Control (Bank 2)
P1320
Ignition Signal
P1211
ABS/TCS Control Unit
P1212
ABS/TCS Communication Line
P1217
Engine Over Temperature (Overheat)
P1320
Ignition Signal
P1335
Crankshaft Position Sensor (REF)
P1336
Crankshaft Position Sensor (CKPS)
P1400
EGRC Solenoid Valve
P1401
EGR Temperature Sensor
P1402
EGR System
P1440
EVAP Control System Small Leak
P1441
Vacuum Cut Valve Bypass Valve
P1444
Canister Purge Volume Control Solenoid Valve
P1445
EVAP Canister Purge Volume Control Valve
P1446
EVAP Canister Vent Control Valve (Closed)
P1447
EVAP Control System Purge Flow Monitoring
P1448
EVAP Canister Vent Control Valve (Open)
P1464
Fuel Level Sensor Circuit (Ground Signal)
P1490
Vacuum Cut Valve Bypass Valve (Circuit)
P1491
P1492
EVAP Canister Purge Control/Solenoid Valve (Circuit)
P1493
EVAP Canister Purge Control Valve/Solenoid Valve
P1550
TCC Solenoid Valve
P1605
A/T Diagnostic Communication Line
P1705
Throttle Position Sensor Circuit A/T
P1706
Park/Neutral Position (PNP) Switch
P1760
Overrun Clutch Solenoid Valve (Circuit)
#658796 - 18/04/08 05:58 AM Re: OBD II Codes
Digimoto Forum
Forum for OBDII codes.
