I figured out how to take the glass panel off. I had to loosen the roof rack, then remove the rear mounting bolts for the sunroof. Then I lifted it upright and slid it off of the front retaining pins. The bad news is that all of the mounting holes had recesses in them so it only fits in one position and cannot be moved. The leading edge of the weatherstripping is still barely hanging on. If I use the sunroof, the leading edge will tuck downwards into the gap, causing water leakage again. It looks like I may have a defective sunroof if this is not normal. If I look at someone elses and it is good, I will bring mine to the dealer for service. Does anyone have the wind deflector removed so they can tell me what the moulding on the leading edge of the sunroof looks like, and how much overhangs onto the body of the car (like the rest of the moulding), or is it tucked down?
Chris
'00 Xterra SE 4X4 Auto(Silver Ice)
Chris
