#675538 - 08/05/11 08:40 AM Throw Out Bearing
therob Offline
Loc: Albuquerque, NM
I've been experiencing a squeal during acceleration. My initial thought was that the fan blades were rubbing on the shroud but I've checked and trimmed some suspect areas but it continues.
I'm thinking it has to be the throw out bearing because I've also experienced some warbling noise while in neutral.
I've does some poking around with search feature and have gained some insight into what it takes to replace the throw out. I assume that I should go ahead and replace the clutch and have the flywheel machined while I'm in there (?). What else should I consider? Also, I didn't really find a tutorial on changing the clutch here, anyone have a link?
Robert
FYI I'm 99% positive it is not a belt squealing.
Edited by therob (08/05/11 08:41 AM)
#675543 - 08/05/11 11:51 AM Re: Throw Out Bearing [Re: therob]
I WOULD spend a little time making 100% sure that it wasn't a belt.
For example, you DIDN'T mention if clutching in/out or going in reverse changed the noise....or if you marked the belts with chalk lines against the pulleys to make sure they didn't slip, or, tried turning on AC, lights, radio, fan to high, etc...to see if a belt slipped when the alternator hit a heavy load all at once, etc.
And, sure, if you're in there, take care of the pilot, the throw out, the clutch, etc...but, typically you don't need to machine the flywheel too, unless things got really buggered, in which case, you'd look at the starter cog too.
#675544 - 08/05/11 12:10 PM Re: Throw Out Bearing [Re: TJ]
therob Offline
Yeah, it isn't any of the belts. I've ruled out belts completely. It seems to happen when the engine is at really low rpms and the clutch is being engaged. How do I describe this... its that point where you release the clutch slightly and press on the gas at the same time... the friction point? it only does it when I'm accelerating from a stop and it happens nearly every time, the severity relies on how quickly I release the clutch and how much gas I give it.
I plan on ordering OEM parts from the dealer or from Xterraparts.com but do you have any specific recommendations besides that?
Thanks for the quick response BTW
#675549 - 09/05/11 05:33 AM Re: Throw Out Bearing [Re: therob]
Its a pretty straight forward procedure, about like any other clutch work you've probably done, but does require you get all the stuff in the way off first...
I think I mentioned looking at the starter cog while your at it, and doing the pilot as long as you're doing the TO bearing, etc.
#675897 - 23/06/11 06:28 PM Re: Throw Out Bearing [Re: TJ]
Nissan_MasterTech Offline
Loc: Florida
Probably not the TOB, most likely the hamonic balancer has seporated, common problem.
#675900 - 24/06/11 06:34 AM Re: Throw Out Bearing [Re: Nissan_MasterTech]
Nail Bender Offline
Loc: chicagoland
How do you fix that?
Therapy is extremely expensive, popping bubble wrap is radically cheaper, you choose which one helps with your problem, I'm gonna get some sleep!
#675904 - 24/06/11 03:49 PM Re: Throw Out Bearing [Re: Nail Bender]
Loc: Florida
You remove all the belts, then remove the harmonic balancer .
then you got to the dealer and buy a new one and install everything in reverse order .
#680085 - 18/05/13 07:08 PM Re: Throw Out Bearing [Re: Nissan_MasterTech]
slantyshanty Offline
Loc: Northern Michigan
I know this is a pretty old post but my X has started doing exactly what you describe. Worst in 1st and 2nd gear. Sounds like birds. My X only has about 60k miles or less but has been through some pretty rough times over the years and terrain across the U.S. I am not familiar at all about clutch work or harmonic balancer work at all. What are some things to do to prove one thing or another, as I would hate to dig into one thing only to find out it was the other? How long can you drive like this before failure? Mine has only been doing this for about 2-3 weeks (that I have noticed) but does seem to be getting worse.
