#676849 - 24/10/11 09:58 PM Newbie needs trans help!
joshSoCal Offline
Hi all. I am new here. Bit of background. My 2nd 04 xterra and love them. The one I have now is a 04' V6 manual with 111,000 miles on her now. I have a huge issue I need help with. The trans is stuck in 3rd gear. I accelerated to to 3rd and tried to downshift and it just was stuck in 3rd nothing i could do. I pulled to saftey in a parkinglot. the cluth works, I can press the clutch and roll the truck. I can start it but cant get it out of 3rd. I replaced the clutch about 5000 miles ago, made sure the trans fluid was full and now this. I am at a loss. I'm not sure if it is a sycro, or if there is something else in there it could be. I am not afraid to do the work I just need my truck back on her feet. Any help would be awesome. Thanks
#676877 - 29/10/11 07:48 PM Re: Newbie needs trans help! [Re: joshSoCal]
Nissan_MasterTech Offline
Loc: Florida
The bottom line here is the transmission will need to be removed and opened up. There are a couple of possibilities that could cause the problem.
A. A broken shift fork or roll pin that attches the fork to the striker rod
B. An interlock issue, an interlock problem could let the trans get stuck in 2 gears, in your case 3rd and 4th as they are both on the same hub.
Edited by Nissan_MasterTech (29/10/11 07:48 PM)
