139
#676940 - 10/11/11 07:07 PM
Head gaskets are fun!
Well, add me to the list of Xterras with bad head gaskets. It's been leaking just a little bit for quite awhile (white smoke for a few minutes at startup after it's been sitting for a while). I ordered all the stuff today and will be working my way through it over the next several weeks. Luckily I have several vehicles these days so I can afford to take my time and have the X down for as long as it takes. I'm not sure how helpful pictures will be since others have already posted pretty good ones ( here's one), but I probably will anyway.
#676954 - 11/11/11 12:39 PM
Re: Head gaskets are fun!
[Re: XOC]
I poured in a bottle of head gasket repair back in ~ 2006...never had to do anything else to it.
#677087 - 22/11/11 09:55 PM
[Re: XOC]
Still working on this and taking my time - have lots of pics I'll put up eventually.
I'm almost through with the teardown... the driver side head is ready to be unbolted and removed.
The passenger side head is almost ready - I have to figure out how to take the power steering pump and the bracket it's attached to off first.
I gave up on the engine block water drain bolts - they aren't going to budge. Hopefully that's not too big a problem.
A friend who knows more than I do is coming to visit on Friday and we'll actually pull the heads off, check them out (as much as is possible in my garage... is it a mistake to not send them to a machine shop to be checked?), and start putting things back together.
Hopefully the heads aren't warped or anything - they shouldn't be - I am the original owner and I know it's never been overheated and it's only got about 160k miles on it.
I need to read up on that knock sensor relocation thing since I'm in there and I've had that code (P0325 I believe) active for ever. I went to pick up a new knock sensor today but they wanted over $200 for it so I didn't buy it.
#677233 - 10/12/11 03:37 PM
[Re: Kaiser]
hmmm... very very noisy... concerned. I don't know if the lifters are just dry and a bit of running will fix it up, or what. I've run it twice so far, for a total of probably 4 minutes. I took a video of the first startup - I took a video of the first startup - HERE. (now on youtube - easier to see) Any advice/opinions?
Edited by Kaiser (10/12/11 05:11 PM)
#677235 - 10/12/11 05:08 PM
[Re: Nissan_MasterTech]
I didn't remove the lifters - we just backed out the bolts on the bar that holds the rocker arms enough to get those two captive head bolts out and put new ones in.
I just tore it down, replaced the gaskets, and reassembled - no work on the heads because I didn't think they needed any. The valves didn't seem to leak any when we sprayed carb cleaner at the back sides of them
#677237 - 10/12/11 07:45 PM
[Re: Kaiser]
woo hoo! It seems to be fine! I decided to take Master Tech's advice and just go drive it around and within a few seconds of starting this time (which is the 3rd start since the head job) the noise went away! http://youtu.be/A3Is2woCgJ0I drove it for several miles and got it up to 60 or so - everything seems fine except that it's idling a bit high... but I haven't adjusted the timing so that might account for that.
#677238 - 10/12/11 07:49 PM
Hmm - well now I feel stupid for not getting them done... I didn't know where to take them and didn't want to spend the money so I skipped that part. oh well.
The truck has 149k on it
#683015 - 17/01/17 09:46 AM
[Re: Kaiser]
Good thread. Heads looked good too. What did you use to clean the heads and the block surface? I'm having trouble with all the old graphite material sticking to them.
