Yak, Welcome! Love the name BTW. I've been to Nepal twice where they USE yaks! Wonderful beasts too. But I digress...
I think it makes sense that it's the power plugs on the door too. Should be a simple fix. A PITA to get to, but once there, it should be pretty easy.
However, to throw this out, since I don't know where you are, is it cold there? Like freezing? I have a similar problem that may be related. My hatch lock won't unlock if it is cold. I can unlock it with the key just fine, but the electrics won't unlock it. The other doors work fine, just not the hatch. Once it gets above freezing, it's fine. My guess is that it probably needs some lube, because if it's in the mid-thirties it will unlock to the point that when I pull the handle, it will unlatch to the safety catch, but not fully. Other times it won't unlock at all. Again, depending on the temp. The colder it is, the less likely it will unlock. Below freezing, all bets are off. But it's not a big enough of a problem (yet) to take the panel off the inside of the hatch and fix it. So, what I'm suggesting is that it may be temp related. Just a thought.
-G
'03SE
BFG AT/KO
Pre-crash post count - ~1100
