#678087 - 06/03/12 12:11 PM 2001 Xterra won't start - replaced battery and starter
Alyssa Offline
I have a 2001 Xterra XE that won't start. All lights work, clicks when ignition is turned. Son is ASE mechanic. Replaced battery and starter (actually twice, thinking the first one he bought was bad). Car won't start! Don't have the tools to check computer. Thoughts?
#678088 - 06/03/12 02:12 PM Re: 2001 Xterra won't start - replaced battery and starter [Re: Alyssa]
sdxterror Offline
It sounds like the starter relay is working since you here the clicking but you should double check. Also, check the input signal to the starter. See if there is a voltage there when you turn the key.
#678089 - 06/03/12 02:13 PM Re: 2001 Xterra won't start - replaced battery and starter [Re: sdxterror]
sdxterror Offline
Check fuses both under the dash and in the engine compartment. Maybe one is blown?
#678091 - 06/03/12 06:32 PM Re: 2001 Xterra won't start - replaced battery and starter [Re: sdxterror]
Nissan_MasterTech Offline
Loc: Florida
Is it a manual or automatic
