Ok, you can do this. Start with the easy checks and work your way up. Remember the basics:
Check for spark
Check for fuel
Check for compression
Check the timing
You'll be best at figuring out what may have been missed when it all went back together, but here is where I would start:
Double check:
Distributor/coil wiring harness
Intake manifold vacuume hoses and other control connections
Are the Plug wires on the correct cylinders - What about on the right posts at the cap?
If spark checks out good move on to fuel delivery and so on
Good luck,
Saturday
