#69115 - 02/08/04 06:52 AM Yakima Wheel Fork
Anyone else have trouble with theirs? Mine never stays standing up, every time I get to the trail, I get out and find the tire resting on the roof. I can't tighten it anymore. Probably something just have to deal with?
#69116 - 02/08/04 09:42 AM Re: Yakima Wheel Fork
buffalo Offline
Loc: los angeles, california
Yeah I have the same problem. I decided to use mine only when absolutely necessary. Another problem, Twice I've discovered that I didn't tighten the skewer enough and lost the end nut, had to scratch riding that day. For the most part my wheels never get muddy enough to worry about throwing them in the back, just dusty.
use the SEARCH function! Now you know... and knowing is half the battle!
#69117 - 02/08/04 10:03 AM Re: Yakima Wheel Fork
Thanks for the reply. Guess it's going in the back for the most part. I get nervous that I'm going to see it chasing behind me down the road.
#69118 - 06/08/04 05:46 AM Re: Yakima Wheel Fork
2 the X Offline
Loc: Manassas, VA.
The best trick to keep a wheel fork from dropping the wheel onto the roof is to apply some 3M grip tape similar to what you find on stair cases around the cross bar and then mount the wheel fork brackets around the tape. . .it'll give a "rough" surface not allowing the brackets to slip. Hope that helps.
#69119 - 06/08/04 12:56 PM Re: Yakima Wheel Fork
Mapman Offline
Loc: Crystal Lake, IL
Mine have always done that, I never really worried about it though. I just make sure to tighten eveything good and tight! Hell I made it from Denver to Chicago and back again with 4 bikes and 4 tires up top and didn't lose anything!
Formerly known as EAP
http://midwestxterraowners.com/
#69120 - 06/08/04 01:13 PM Re: Yakima Wheel Fork
Thanks for the suggestions...going to give the tape a try.
#69121 - 06/08/04 02:03 PM Re: Yakima Wheel Fork
Ramness Offline
Loc: Snellville, GA (Atlanta)
No wheel forks for me, I put the wheel in the basket or in cargo area. On Need-a-hammers's truck we put the wheels in the wheel forks and tip them over where the tires rest in the gear basket.
