#72988 - 07/11/07 03:04 PM Spacers or BL?
I want 33" tires and am going to be doing mild off-roading (just mud, no rocks or anything extreme) so I have to get a lift of some kind. I do not want a suspension lift because 4WheelParts quoted me about $1,500 for a ~2" suspension lift. I don't want to spend that much.
So should I get a 3" body lift:
http://www.4x4parts.com/public_html/shop...ae95d53e43b1b5b
or get spacers? Thanks
#72989 - 07/11/07 05:37 PM Re: Spacers or BL?
Kaiser Offline
What are spacers? wheel spacers?
#72990 - 07/11/07 06:06 PM Re: Spacers or BL?
Second Gen.
#72991 - 07/11/07 08:30 PM Re: Spacers or BL?
Kaiser Offline
oooh - you're talking about those coil spacers... seems like a good way to go to me if all you want is height and not articulation.
They're certainly easier than a BL
#72992 - 13/11/07 12:49 AM Re: Spacers or BL?
Nether to fit 33's, 2005+'s can fit 33's stock, with no lift of any kind at all.
And...as far as articulation goes...I doubt you could tell the difference between a longer coil and a coil spacer'd X....the front tires will droop just like they would with a longer coil...the IFS will still go from stop to stop, same as stock, just ride higher...
...and the rear doesn't have a coil, so its the same as a shackle lift on an old X, etc.
#72993 - 13/11/07 04:25 PM Re: Spacers or BL?
Ok so 33's will fit but will they rub, or touch, when I am driving/turning? How about a small amount of mudding?
#72994 - 14/11/07 04:28 AM Re: Spacers or BL?
LOL
32's are a stock size...33's only stick out another 1/2"...not enough to matter.
Your wells are a little narrow due to the bulgy plastic fender liners, so if you get 33x12.5's for example, it will rub the plastic liner on compression/turns, but people have trimmed the plastic inside the wheels back, or even heated it with a blow dryer to shrink it back. (Plastic liners also "self clearance" with wear...)
285/75/16's fit easily, on alot of new X's with no trimming at all, others, a little plastic at most, 305/70/16's also fit, but I don't know any new X's running wider than the 12.5's.
(The 305/70/16 is roughly a 33x12.5/16 equivalent
The 285/75/16 is roughly a 33x11.5/16 equivalent
The Stock can come with a 265/75/16, roughly a 32x10.5/16 equivalent)
