#73105 - 22/03/05 12:07 PM help installing shrockworks sliders
I am just now getting around to putting on my sliders i order in Jan. (Damn the Air Force)
can one of you help me out. The instructions say The plate with 3 holes goes in the rear. I don't have a plate with 3 they all have 2.
how do i know which one is the front, or doest it even matter.
#73106 - 22/03/05 12:50 PM Re: help installing shrockworks sliders
xterraintx Offline
Loc: Eddy, TX..
Does not matter... match the holes with those predrilled in the frame.
Round side up wink
#73107 - 22/03/05 01:11 PM Re: help installing shrockworks sliders
THANKS I THOUGHT THAT WAS IT BUT WANTED TO MAKE SURE.
#73108 - 23/03/05 10:08 AM Re: help installing shrockworks sliders
The flange that has been cut at the corner gets mounted at the rear
#73109 - 24/03/05 12:09 PM Re: help installing shrockworks sliders
I just Picked them up from LineX going to install them tonight.
thanks.
#73110 - 24/03/05 02:53 PM Re: help installing shrockworks sliders
Lincoln Offline
Loc: Wisconsin
Get someone to help you. I was able to do it by myself, but it would have been worlds easier with 2 people.
#73111 - 25/03/05 03:13 PM Re: help installing shrockworks sliders
What a pain in the A$$ the holes did not line up well at all. i have 2 bolts that will not go in and some that get tight but the bolt sticks out 1/4 inch. Anyone els have this problem
#73112 - 25/03/05 03:16 PM Re: help installing shrockworks sliders
Make sure the threads weren't linex'd..
#73113 - 25/03/05 04:41 PM Re: help installing shrockworks sliders
Lincoln Offline
Loc: Wisconsin
Mine didn't line up that great either, you have mess with it.
Make sure that none of the bolts are in tight, back them all out and reposition until you can get all bolts in. Then tighten each bolt a little at a time.
Patience my son.
#73114 - 25/03/05 05:31 PM Re: help installing shrockworks sliders
I just ordered sliders from calmini any problems with mounting them?
#73115 - 25/03/05 07:39 PM Re: help installing shrockworks sliders
There is nothing wrong with the sliders i think it is the nut plates on the frame. i may have to drill through them and install with a bolt and a nut.
All the holes line up on the sliders and the factory holes on the frame just crappy nut plates.
#73116 - 25/03/05 08:21 PM Re: help installing shrockworks sliders
Rickster43 Offline
Loc: San Antonio,Texas
WOW...Ron Jeremy, Welcome to XOC...I've seen some of your best movies...Classic stuff...I like the one with you and Jenna Jameson...
Your Personal CADD Monkey...
#73117 - 25/03/05 08:28 PM Re: help installing shrockworks sliders
I liked it too.
#73118 - 25/03/05 09:38 PM Re: help installing shrockworks sliders
Shrock Offline
Loc: Houston, TX
Sometimes the threads are full of undercoating gunk. You can try running am M10 x 1.25 tap through them to clean them up.
Jim Shrake
www.ShrockWorks.com
#73119 - 26/03/05 04:44 AM Re: help installing shrockworks sliders
I only had trouble with one... the 7th bolt on the one side... took off some piece of rubber on the frame and it went no problem!!
#73120 - 26/03/05 05:36 AM Re: help installing shrockworks sliders
thanks Jim i will try that there are only two that are giving me trouble.
#73121 - 26/03/05 05:58 AM Re: help installing shrockworks sliders
Xorand Offline
Loc: LA (Lower Alabama)
If you haven't had step rails on in a while (or at all), the bolt holes will get gunked up. I used to remove my step rails before I went off road, then reinstall them when I got home.
I boogered up a couple of the bolts by cross-threading them in dirt-filled holes. With the fine threads used by Nissan for the step rails, it's easy to do.
I installed my Shrocks by myself and didn't have any problems lining everything up.
2002 Just Blue XE 4x4
#73122 - 28/03/05 08:04 AM Re: help installing shrockworks sliders
New porn capitol: Omaha. Whoda thunk it.
#73123 - 28/03/05 06:12 PM Re: help installing shrockworks sliders
Just got done Tapping my holes. boy am I tried. any way got most of the screws in only one is giving me trouble. thanks Jim for the Idea of using a Tap.
#73124 - 29/03/05 08:50 PM Re: help installing shrockworks sliders
Rickster43 Offline
Originally posted by Ron Jeremy:
...Just got done Tapping my holes. boy am I tired....
Sounds pretty Kinky, Ron...
