#75239 - 02/08/06 02:33 PM Which side of the fuse?
What side of the fuse is "hot" on our Xterras? Or are they all different? I want to put a fuse tap on to power a scanner. Also, does anyone know of a ground on the passenger side? All the screws and metal parts seem attached to plastic. Thanks.
#75240 - 02/08/06 02:49 PM Re: Which side of the fuse?
You will need a meter to find out for sure. Pull the fuse out, also find a good ground. Test both sides of the fuse socket. you might want to make sure it has power when you want it to have power.
#75241 - 02/08/06 07:43 PM Re: Which side of the fuse?
both, till the fuse blows..
#75242 - 03/08/06 07:10 PM Re: Which side of the fuse?
xcanuk Offline
Loc: Mtl. Que. Canada
Usually left side has power, but you'll need a tester as mentioned, same for the ground.
Do 2006's have spare fuse slots that are powered ? (2000's have 2)
member of http://www.soxc.org
