#78283 - 27/08/02 01:53 PM yakima rack question
Taylor S Offline
Loc: Victoria, BC
I'm thinking of putting a yakima loadwarrior on the roof of my 2002 'X' SE. The problem is that I want to keep the stock basket over the sunroof. I am also planning to mount some lights on the front roof crossbar. I'm wondering if anyone knows if this will fit. I don't want to buy the yakima loadwarrior if it needs to be mounted on the front crossbar. Thanks for any help you guys can provide.
#78284 - 27/08/02 02:40 PM Re: yakima rack question
p.i.n.o. Offline
Loc: Sugar Land, TX
If you are mounting the loadwarrior to the crossbars, then you will need both of them. Yakima sells light mounts that attach to the loadwarrior so you may not need the front crossbar. The loadwarrior is short enough lengthwise that it will not interfere with the stock roof basket.
#78285 - 27/08/02 04:13 PM Re: yakima rack question
mineralblue Offline
Loc: Downtown Houston, TX
The stock Loadwarrior will fit, leaving the gear basket usable... just be sure to move the crossbars back a bit so everything fits...
Do not get the Loadwarrior extension if you plan on using your factory basket... otherwise your roof will look like this...
Boarderphreak\'s Roof
As for lights, I agree with lilpino, get the Yakima light mounting brackets and mount them like you see on Boarderphreak's roof.
You should listen to your heart, and not the voices in your head. - Marge Simpson
#78286 - 27/08/02 05:26 PM Re: yakima rack question
BoarderPhreak Offline
Loc: Huntington, NY
MB's right - just get the LW itself, no extension. Use both crossbars to mount it, which may require adjustment from their stock/current positions.
As for lights, get that one that was listed on Ebay and posted here for like, $75. That seems to be a nice, sano solution (I just don't care for the two *screws* holding it all on).
Or, my suggestion - the Yakima Light Bar Brackets for $30ish. Mounts two lights as seen in that linked photo above by MB... Or, like what I'll probably do - is fashion a bar to go betwixt the two mounts for four lights...
#78287 - 02/09/02 03:38 AM Re: yakima rack question
Khaki_SE_X Offline
Loc: Baltimore
I just installed a Load Warrior (With Extension).
Without the extension, it will work just fine.
With the extension you could still leave the front basket in (and not be able to remove it). However, you would only have about 5" to 8" between the Load Warrior and the wind deflector. Enough room to put small items. I just took my front basket out. I personally found it totally useless.
If you order a Load Warrior extension, it comes with a "Load Bar", which looks like it might be strong enough for a few lights. Or.. you can order the light brackets (for around 30 bucks).
Agee\'s Bikes sells Yakama products.. the are giving 20% on major purchases that you can use for smaller items like light brackets and nets. And they are also offering free shipping. eek
HaPpY Trails,
Ken
