#90188 - 05/05/05 09:16 AM Aligning aux lights on Megawarrior
Ok guys Im having a tough time aiming my lights on my megawarrior with the yakima braket. My lights are hella rallye 4000's which dont seem have any up down adjustments just left right... I have them centered, I just need them to point a little more down.... Any ideas?
#90189 - 05/05/05 06:56 PM Re: Aligning aux lights on Megawarrior
Not sure if this will help, but on the brackets which side did you mount them to (top or bottom)? I noticed with mine it had to either be on the top of the bar or the bottom to mount properly with the brackets mounts that were supplied.
#90190 - 05/05/05 08:09 PM Re: Aligning aux lights on Megawarrior
Heres a pic of one of them mounted. Its from the top
Hope that helps. i thought about putting spacers on teh bottom two mounts so that it effectivly tiltis the lights down a bit. im sure I can figure out some way, I just wanted to find out if someone has this setup and already went through my pain frown
#90191 - 05/05/05 11:19 PM Re: Aligning aux lights on Megawarrior
Turn the rear mounting holes into vertical slots by cutting or grinding. Then put shims under the brackets.
