#96422 - 14/04/04 03:28 PM Cleaning up after mudding
Hey guys, I did a search on this and didn't find anything, chances are I will get a response saying I didn't search hard enough cause I am sure this has been talked about here but I was wondering what I should clean after I go mudding, I was told somewhere that I shouldn't clean the engine but something like the engine tray. I don't know a ton about pieces of cars and all so if someone could tell me what I should make sure to get when cleaning and where to get to these places in the truck...thanks
#96423 - 14/04/04 03:45 PM Re: Cleaning up after mudding
socalpunx Offline
Search the Appearance forum with the subjects "mud" , "muddy" and "muddy engine" and it looks like there is plenty there to get you started.
#96424 - 14/04/04 04:26 PM Re: Cleaning up after mudding
I just go to the local car wash place, rent a power washer and search for mudd anywhere in the under carriage... usually where you see a little... there is a lot more hidden. if you look under the skid plates there is a lot of mudd... make sure you clear it away from moving parts.. you dont want sand a grit getting into barrings.
if you are going to wash the motor, make sure its cold and everything is off. and be somewhere where you can leave it off for a while.
someone already has suggested... get a sprinkler, one of those ones that sway back and forth... and just leave it under your X while moving it around about every twenty minutes... after about an hour most of the mudd should be removed.
#96425 - 14/04/04 05:58 PM Re: Cleaning up after mudding
BurgPath Offline
Loc: Knoxville, Tn
I'm sure that would work but the thought of it cracks me up.
I can see my fiance asking me, "Are you watering the truck?"
Kevin
- 2008.5 Titan SE 4x4
