#97047 - 02/12/00 12:45 AM Rear breaking loose on gravel roads
deanf Offline
Loc: N47º 06’ x W122º 22’
A while back we drove our X on some steep and winding gravel forest roads. We're not talking 4x4 trails here, just 1-lane gravel roads.
At moderate speeds (25 mph or so), when taking corners, the back tires would break loose just a little bit and the back end would begin to slide. I'm used to driving a Suburban, and that's never happened.
Anyone else?
I'm a constitutional fetishist.
#97048 - 02/12/00 08:07 AM Re: Rear breaking loose on gravel roads
lasersailor Offline
Loc: Waccabuc, NY, USA
Me too. I live off a dirt road that gets the washboard effect over the winter (you know the little groves about an inch thick and an inch apart), and it seems like whenever i go around a curve, even if i'm not going that fast, the back bounces, and swings out to the side.
I tried it in my mom's grand cherokee and it didn't seem to be as bad as in the X. I don't understand it because there about the same size and the X is fairly heavy.
#97049 - 20/12/00 02:18 PM Re: Rear breaking loose on gravel roads
MichaelShaw Offline
Loc: Dallas, TX
The back end breaks loose easier becuase chances are you have the limited slip in the rear. Rather than one tire completely giving up traction, they both spin in the turn and that breaks the back end loose faster.
Hope this helps
Michael
Veritas Liberabit Vos
-kai-
#97050 - 23/02/01 11:14 AM Re: Rear breaking loose on gravel roads
miket Offline
Loc: big island, hi
I've had similar experience in my 2001 SE 4x4. I noticed significant improvement by knocking down the pressure in the rear tires, especially when I've got them at higher pressures for road driving.
I run these approximate cold pressures:
ON ROAD:
REAR: 37psi
FRONT: 39psi
This yields a comfortable ride, yet efficient mpg. The steering response more precise and the roll is less with the fronts at a little
higher pressure.
OFF ROAD:
REAR: 34psi
FRONT: 34psi
For the moderate off-road washboard stuff originally described this has worked well for me. No kicking out in the choppy stuff. The tires can be run much lower down to around 24 according to the sticker in my glove box. I'd only use that for real gnarly mountain trails.
Cheerio,
MikeT
2001 SE 4X4
Rain+Dirt does it for me.
2001 SE 4X
Rain+Dirt!
#97051 - 23/02/01 12:43 PM Re: Rear breaking loose on gravel roads
Rumpy Offline
Loc: Bayside, NY
Wait, I'm confused. I thought we were supposed to run the tires at 27 PSI. Your numbers are way higher. One of us is wrong here...No offense but I hope it is you.
#97052 - 23/02/01 01:11 PM Re: Rear breaking loose on gravel roads
Philosopher Offline
It's definitely him. Those pressures are WAY to high for the stock tires (I'm assuming the stock tires are on there).
I run my 32 x 11.5 M/T's at:
35 psi front onroad
30 psi rear onroad
10-18 psi front offroad
10-18 psi rear offroad
... depending on trail conditions.
philosopher@angelfire.com
Philosopher's Xterra
Mid-Atlantic Xterra Club
#97053 - 23/02/01 01:54 PM Re: Rear breaking loose on gravel roads
Rumpy Offline
Loc: Bayside, NY
Thank god....I thought I was heading for a Firestone incident......
#97054 - 25/02/01 12:31 AM Re: Rear breaking loose on gravel roads
miket Offline
Loc: big island, hi
true, the recommended pressure is ~27psi. on-road, so low of a pressure makes for a sloppy ride. it also knocks a few mpg off. i had the skittish back end too, taking a few pounds out of the rears helped.
the stock tires on mine are rated to 44psi. so, i wouldn't say 37 is way too high.
when you were getting the bouncing, what was the rear pressure?
T
2001 SE 4X4
Rain+Dirt do it for me.
2001 SE 4X
Rain+Dirt!
