131
3
#98083 - 19/12/05 07:16 AM
Re: Hi-Lift Jack mounting location
Originally posted by 2manytoyz: Would probably have to use the wheel hooks to do anything with the front end. Problem is, how do you change a tire if you are picking it up with the tire? To be honest, not sure where you could use it without sliders or bumper.
#98084 - 21/12/05 09:53 AM
Originally posted by Muzikman: Problem is, how do you change a tire if you are picking it up with the tire? Actually, that's not when I'd use it... or when I've used one with prior vehicles. The issue here is sugar sand. Yes, it honestly is as white as sugar. It's as loose too, and if you screw up, you'll spin your tires and end up on your frame in half a second. Don't ask how I know. I've only had this happen with 2WD vehicles, fortunately. Now your chassis is hard down on the ground, with no way to get the factory jack under it. Along comes the Hi-Lift jack to grab a bumper, hitch, or wheel, to get it up out the holes. The sand is pushed back into the craters, and with caution, you can then proceed once again. On the trails, I use my factory jack and a block of wood (so the jack doesn't sink) to change a tire.
#98085 - 21/12/05 10:09 AM
#98086 - 05/01/06 01:30 PM
#98087 - 05/01/06 02:01 PM
You need to host the picture some place and then just use the UBB Image tag to display the picture.
#98089 - 06/01/06 11:03 PM
I tested the upward pressure on the clips that hold the seat cushions down just to see how much I could pull up on it and not have it let go. I used a piece of strapping and tied it to my fish scale. I wrapped the strapping under the seat cushions and out the sides really close to the clips. I got the scale to read about 35 lbs. and didn't want to go past that obviously because I didn't want to break it. I'd figure that theoretically, you could apply at least 70 lbs. of pressure along the entire length of the seat cushions at the clips. With the jack being at the pivot point of the seat cushions, you could probably say that it would need to apply a lot more pressure since it's at the losing end in terms of leverage. I feel confident that the seats will stay locked on a roll over. I think.. or hope.
#98090 - 16/03/06 03:00 PM
I don't know if anyone else has done this, but I drilled 3/8" holes in the stock rear bumper and put a long bolt with 1 1/2" fender washers against the bumper, put a nut on that, slid the hi-lift onto the remaining stud portion of the bolt, then finished it off with a 3/4" washer and a nut.
#98091 - 17/03/06 12:38 AM
anyone every place hooks on the back of the seats and ratchet strap the high lift to the back of the seats??
#98092 - 17/03/06 10:10 AM
I lay it on the back seat, and seat belt it in.
#98095 - 19/03/06 10:58 PM
where can u get some of those fourtrex clamp?
#98096 - 20/03/06 07:49 AM
#98097 - 20/03/06 09:04 AM
#98098 - 20/03/06 10:47 AM
Looks good. I think Jim should angle the mount though. That way those of use that have 60" lifts could still mount them without clearing the tree branched over head.
#98099 - 20/03/06 12:35 PM
I think it could be angled by just using the supplied wing nuts and backing nuts....hmmm....might try that...
