#98153 - 01/11/03 03:19 PM Shifting from 4wd to 2H problems...
Today I went 4 wheeling and I could not get my truck to shift back into 2H after coming out of 4H. It took me a good 5 min to get the damn lever up to 2H. What is the deal? Am I doing something wrong. I've had problems before too but not this much. Do I have to reverse a few feet in 4H then stop and shift to 2H? I know after you are in 2H you need to reverse to unlock the hubs but I can't even move the damn lever up to 2H. It is anything but easy.
I did search too and wasn't happy with any posts I read through.
#98154 - 01/11/03 04:36 PM Re: Shifting from 4wd to 2H problems...
Rickster43 Offline
Loc: San Antonio,Texas
Just wondering, did you have it on 4LO also, and tried to switch it to 2HI from 4HI with your transmission on Nuetral...
Your Personal CADD Monkey...
#98155 - 01/11/03 05:00 PM Re: Shifting from 4wd to 2H problems...
Well, I went into 4H... then drove around alternating between 4H and 4L. Ending up in 4H before making it back to pavement.
Then I couldn't get it back to 2H. What happened is the trail was mild and got worse so I switched to 4L... then on the way out just the opposite. What a bitch to get back to 2H though.
I just tried it again in my parking lot and it went into 2H no problem from 4H to 2H and from 4L to 2H. So, I guess it was because I was driving around alternating 4H and 4L that it was a pain to get back?
#98156 - 01/11/03 06:14 PM Re: Shifting from 4wd to 2H problems...
When you stoped to put it back in 2wd where you on a hill?
#98157 - 02/11/03 03:14 AM Re: Shifting from 4wd to 2H problems...
Nope, flat surface.
#98158 - 05/11/03 10:17 PM Re: Shifting from 4wd to 2H problems...
i have the exact same problem. can't figure it out...
#98159 - 06/11/03 09:51 PM Re: Shifting from 4wd to 2H problems...
I think I figured it out.
4H to 2H you need to be in drive and moving a tad.
4L to 2H you need to be in neutral. If you go to 4H first then you need to be in drive before 2H.
Thats what I figured out on my own... dunno if its correct but it works.
#98160 - 06/11/03 09:57 PM Re: Shifting from 4wd to 2H problems...
I'm always moving when I try to switch back into 2... still doesn't work
#98161 - 16/11/03 04:08 PM Re: Shifting from 4wd to 2H problems...
you have to push the shifter down and forward at the same time
#98162 - 16/11/03 10:52 PM Re: Shifting from 4wd to 2H problems...
Take your foot off the gas and coast. You must shift without any load on the transmission.
