#99095 - 05/02/04 05:24 PM Crazy steering in 4wd
Saline Offline
Loc: Fruita , CO
I've never had a problem with this truck until now. I was in the snow/pavement mix yeserday in 4wd and the steering moved wildly from side to side under even slight acceleration. So bad in fact that I checked to see if I had a flat.
No noises, no grinding, everything appears to be tight.It has a 3" suspension lift and 76k miles. I have an Idler arm brace also. Is this possibly a bad centerlink/idler problem being magnified by being in 4wd?
Desert Solitaire
#99096 - 05/02/04 06:42 PM Re: Crazy steering in 4wd
OnlyOneDR Offline
Lifted? Lots of Miles? In 4wd?
YES, your centerlink is shot.
I have a pair of stocker CLs I am selling DIRT CHEAP (Not worn, not wheeled). PM if interested.
http://www.noas4x4club.com/
#99097 - 05/02/04 07:34 PM Re: Crazy steering in 4wd
Saline Offline
Loc: Fruita , CO
Would a worn centerlink allow that much erratic movement?
Desert Solitaire
#99098 - 05/02/04 08:02 PM Re: Crazy steering in 4wd
Yes. I have experienced it.
I'm finally back in my lane on a consistent basis. [Wave]
#99099 - 06/02/04 06:20 AM Re: Crazy steering in 4wd
rfritz Offline
Loc: Indianapolis
Oh yeah - My truck is really crazy in 4wd, and my centerlink is toast. We just had a little snow and ice and I left it in 2wd because the front wheels are fighting over each other... frown
#99100 - 06/02/04 09:44 AM Re: Crazy steering in 4wd
Yes, this is why I'm buying the Calmini Steering System first before I put in a lift.
-dp [Smoking]
#99101 - 06/02/04 09:57 AM Re: Crazy steering in 4wd
Saline Offline
Loc: Fruita , CO
I guess I can't complain too much,its had the lift on since 12k miles. Its been to Moab twice as well as countless miles of other 4wd crap.
Rfritz, you're right on with your discription of how it behaves...its like the front tires are fighting with each other!!
Desert Solitaire
#99102 - 06/02/04 11:11 AM Re: Crazy steering in 4wd
I've have someone watch while it's happening to be sure it's the centerlink. Could just be that the front tires are alternately finding traction as the surface varies and power shifts back and forth across the diff...
#99103 - 06/02/04 12:29 PM Re: Crazy steering in 4wd
Saline Offline
Loc: Fruita , CO
I thought of that also, but it even did it on dry pavement .
Desert Solitaire
